description: "NodeActa DMS - Create You Charts."
Charts
You can create different kinds of charts: Pie, Line, Horizontal Line, Fast Line, Bar, Horizontal Bar, Area, Horizontal Area, Point.
  • pie Pie
  • line Line
  • hor line Horizontal Line
  • fast line Fast Line
  • bar Bar
  • hor bar Horizontal Bar
  • area Area
  • hor area Horizontal Area
  • point Point
Creating charts in NodeActa system is simple. You can use ChartView control shipped with the system. Example how to create a chart can be found in Samples→Chart Sample app.
ChartView control is also a nice example how to create a custom control using C++, Delphi or any other environment that can produce a .dll. ChartView is located at System→UI→UI Controls→Chart View and is actually just a wrapper around nodeacta.charts.dll. Also notice that CharView contains 2 dlls, nodeacta.charts.x86.dll and nodeacta.charts.x64.dll. This approach allows you to use the same control for 32bit and 64bit platforms.
Code Example
For information on the available ChartView properties, please explore System→UI→UI Controls→Chart View code.
import { ChartView } from "nodeacta:System.UI.Controls.ChartView";
var chart = new ChartView(this);
chart.width = '500';
chart.height = '500';
chart.view3D = true;
chart.title.text = 'Chart Title';
chart.legend.legendAlignment = ChartView.LegendAlignment.Left;
let bar = chart.series.addBar();
bar.add('label 1', 10, 323, 'Blue');
bar.add(undefined, 10, 133, 'Orange');
bar.add(undefined, 30, 343);
bar.add('label 2', 50, 500);
To save a chart as a file, use the chart.saveToFile(path) method. Provide the path parameter with the appropriate file extension (.jpg, .png, .bmp, etc) to select needed image format.
